Voci con l'etichetta :
Chiudi
Chiudi
Select background color for a paragraph
Background color is applied to the whole paragraph and completely fills all the paragraph space from the left page margin to the right page margin.
To apply a background color to a certain paragraph or change the current one,
  1. put the cursor within the paragraph you need, or select several paragraphs or the whole text,
  2. open the text and paragraph settings panel by
  3. switch to the PARAGRAPH tab,
  4. tap the Background option to open the color palette panel,
  5. select the necessary color on the Theme Colors or Standard Colors palette (swipe it up to see more colors),
    Paragraph Background settings
  6. close the paragraph settings panel by tapping the Close settings panel arrow on the right.
To clear the background color of a certain paragraph, use the No Fill No Fill icon on the Standard Colors palette.
Chiudi
