Voci con l'etichetta :
Chiudi
Chiudi
Select, cut, copy, paste text
Set the insertion point
To position the cursor, touch a text line in the document.
Pop-up menu
The menu options allow you to:
  • Paste previously copied text,
  • Delete the next character within the line of text,
  • Edit text (i.e. open the text/paragraph settings panel).
Select text
Selection handles
To select an object, tap it.
When you select text or object, the pop-up menu appears that contains the following options: Cut, Copy, Paste, More. If you select the More option, a submenu opens that allows to perform the following actions: Delete the selected text or object, Edit it (i.e. open the text/object settings panel) or Add link (this option is only available for the selected text).
Cut, copy, paste text
To cut, copy and paste text passages/objects within the current document use the corresponding options from the pop-up menu that appears when a text passage/object is selected:
  • Cut – select a text fragment/object and use the Cut option from the pop-up menu to delete the selection and send it to the clipboard memory. The cut data can be later inserted to another place in the same document.
  • Copy – select a text fragment/object and use the Copy option from the pop-up menu to copy the selection to the clipboard memory. The copied data can be later inserted to another place in the same document.
  • Paste – find the place in your document where you need to paste the previously copied text fragment/object and use the Paste option from the pop-up menu. The text/object will be inserted at the current cursor position. The data can be previously copied from the same document.
Chiudi
