Skip to main content
ONLYOFFICE workspace Security Guide
Introduction​
ONLYOFFICE provides a wide range of security tools to keep your data safe and to ensure secure collaboration online. This guide describes all the features that allow you to increase the security level of your workspace.
In addition, you can explore some common security technologies, principles, and certain services to ensure maximum security of your server.
General workspace security​
Some workspace features are recognized as industry standards in the field of security: HTTPS, backup, own SMTP server, LDAP.
Secure HTTPS protocol​
ONLYOFFICE allows you to encrypt your traffic using HTTPS protocol. You can easily create a CA-signed certificate on letsencrypt.org and switch your workspace to HTTPS with a single command or apply your own certificates.
Read the corresponding instructions for Docker, Linux, Windows.
Regular backups​
You can back up your data both manually and automatically to avoid data loss. The Backup and Restore features are available as separate sections of the workspace Settings.
To learn more about the backup and restore options, please read this article.
Own SMTP server​
In ONLYOFFICE Apps, the default server for user notification is the ONLYOFFICE SMTP server. For higher security, we recommend using your own SMTP server, so that your messages won’t pass through any third-party services.
To learn more on how to set up SMTP Server, please read this article.
LDAP for access centralization​
You can easily import the necessary users and groups from your LDAP server (e.g. OpenLDAP Server or Microsoft Active Directory) to your workspace. The newly created users, in turn, don't need to memorize new passwords and logins because they will sign in to the workspace using their credentials stored on your LDAP Server.
For more details, please read this article.
Secure access​
The Security section of the workspace Settings allows you to control access to your workspace and monitor the activity of all users.
Password strength​
Strong passwords can help prevent unauthorized access to your data. In your workspace, you can set requirements for the password length and determine the character set that must be used in the password: capital letters, digits, special characters.
Learn more about password strength settings.
Two-factor authentication​
Two-factor authentication ensures more secure access to the workspace. When two-factor authentication is enabled, a user can access the workspace data after entering their regular email and password or signing in via a social media account and typing in a code generated by the authenticator app.
To learn more on how to use two-factor authentication, read the following article.
Other access settings​
  • Specify the trusted mail domains that can be used for user self-registration in your workspace. Learn more.
  • IP security settings allow you to restrict access to your workspace based on the IP addresses by allowing access from trusted networks only. Learn more.
  • Protect your workspace against brute-force attacks by setting up the limit of unsuccessful login attempts by the user. Learn more.
  • Use the Session Lifetime feature to set a time limit during which the users will need to enter their credentials again in order to access the workspace. Learn more.
  • Get notified about suspicious logins. Every successful sign-in is compared with the user's previous login history by three criteria: a new device (the browser and OS pair), a new country, and the number of failed login attempts. If at least two of the three criteria are met, the user receives a notification email.
  • Limit access to the Developer Tools section so that only the workspace owner and administrators can create webhooks, OAuth applications, and API keys. Learn more.
  • You can also manually log out from all active sessions on any device using the corresponding feature in your profile. Learn more.
Login and action monitoring​
Easily track the latest user login activity including successful logins and failed attempts using the Login History section of Settings. The Audit Trail section allows you to browse through the list of the latest changes (creation, modification, deletion etc.) made by users to the files and folders in your workspace. Learn more.
The audit events and the login history can also be forwarded to an external syslog server, which allows you to integrate the workspace with SIEM systems and monitor its activity together with the events from your other services.
Secure storage​
When creating external links to public rooms, custom rooms, or form spaces, you can protect them with a password. For the public or custom room shared via a link, you can also enable the Restrict file content copy, file download and printing option to disable downloads of files and folders. Additional links can be limited by time period.
Learn more about external links.
Virtual Data Rooms for sensitive data​
Virtual Data Rooms provide advanced file security for storing and sharing of confidential business information. The following security features for working with data are available in a Virtual Data room: setting the lifetime of files, prohibition on copying and downloading files, setting watermarks.
  • File lifetime - Set file lifetime to automatically delete the files in this room after a defined period.
  • Restrict copy and download - Enable this setting to disable downloads and content copying for users with the "Viewer" role.
  • Add watermarks to documents - Protect all documents in this room with watermarks.
Learn more about Virtual Data Rooms.
Encryption​
The Encrypt data at rest feature provided by ONLYOFFICE Apps allows you to ensure the security of sensitive data in your workspace.
Encryption is based on the Encrypt-then-MAC type of encryption (AES-256-CBC + HMAC-SHA256) of the entire body of data. It is compliant with the AES-256 international data encryption standard.
Learn more about the Encrypt data at rest feature.
Permission management​
You can assign different permission levels that define what actions with files are available for the user within a room. For example, viewers can only view docs, editors can perform all editing operations with the existing files, content creators can create and upload new files and folders. Learn more.
Secure work with documents​
When co-editing documents, apply a number of security features to restrict access or editing abilities for other users and to prevent the unwanted changes to data.
Document versions​
View version history to know exactly which changes have been made. Restore one of the previous versions of the document if necessary. Learn more.
Document password protection​
Protect documents with passwords to make sure that no-one can access your files without receiving a password from you. Learn more.
Protect workbooks, sheets, ranges​
When working with spreadsheets, you can protect the entire workbook, certain sheets or cell ranges as well as hide formulas or objects. Learn more.
JWT protection​
To protect documents from unauthorized access, ONLYOFFICE editors use the JSON Web Token (JWT). The token is added in the configuration when the Document Editor is initialized and during the exchange of commands between inner ONLYOFFICE Docs services. The secret key is used to sign the JSON web token and validate the token upon the request to ONLYOFFICE Docs.
Basic security principles​
You can also consider using some general principles of server security as well as third-party services and tools not related to the ONLYOFFICE products. Below, you can see some common examples and tips which can be helpful.
Disabling root access​
To avoid data leaks, it is better to disallow logging as root as the root user has full access to all data of the system. This can be done via server’s terminal, by setting the root login permission to No.
Closing all unnecessary ports​
You should keep open only the ports you need for the workspace functioning, as extra open ports can be the cause of data leaks. Use the netstat utility to view all open ports and their associated software.
Setting up a firewall​
A firewall allows or blocks incoming and outgoing network traffic based on the set of predefined rules. In Linux, the firewall is the part of the kernel (netfilter), but you need to install an utility for managing it, for example, UFW for Debian or firewalld for RHEL.
Following the least privilege principle​
Assign only the permissions that are minimally necessary to perform specific tasks, preventing users from accessing sensitive areas they do not need.
Using SSH for remote OS administration​
When administering the server remotely, use the secure SSH protocol. Although this protocol is reliable, you can further strengthen the protection by using SSH keys instead of a password.
Using Fail2ban to secure your login​
Fail2ban can be used to protect your server from brute force attacks. It monitors log files and blocks connections if there are too many failed login attempts.
Enabling SELinux or App Armor​
Enable security modules which protect your server against misconfigured or compromised programs. On RHEL-based systems, SELinux is used. On Debian-based systems, you can use AppArmor.
