File management settings
The file management settings allow you to control your work with documents within rooms and the Files section. These settings are available for all users and guests.
To open the file management settings, click the icon next to your name in the lower left corner and select the Profile option or just click your name. Switch to the File management tab. The following options are available:
- Default Homepage – select the section that opens by default when you log in to your workspace. Use the dropdown to choose one of the available sections: Home, AI agents, Files, Rooms, Forms.
- Don't ask file name again on creation – is used when creating new files. When this option is enabled, a default name will be assigned to the file. If this option is disabled, the user will be able to enter own file name.
- Save the file copy in the original format as well – is used when uploaded files are other than .docx/.xlsx/.pptx. When this option is enabled, it allows you to add a converted file as a new separate file. If this option is disabled, a converted file will be added as a new revision of the original file.
- Display notification when moving items to Trash – is used to hide or show notifications when elements are moved to the Trash.
- Open ONLYOFFICE editor in same tab – is used to open documents in the same browser tab.
- Display file extension next to file name – is used to hide or show file extensions.
- Don't display cancellation notification again – is used to hide or show confirmation notifications when cancelling uploads by clicking the cross next to the floating button.
- Group by rooms – when enabled, rooms can be organized into groups, making it easier to manage and navigate multiple rooms.
