Switching your ONLYOFFICE Apps to HTTPS
If you installed ONLYOFFICE Apps using Docker, you can switch the already installed workspace to HTTPS manually using the letsencrypt.org or own certificate and the /app/onlyoffice/config/apps-ssl-setup file.
When switching to HTTPS, port 443 must be available.
If you want to switch your workspace to HTTPS during the installation from scratch or in cases when you use the DEB/RPM or Windows version, the corresponding instructions can be found in the Installation section.
Using the letsencrypt certificate
If you want to switch an already installed ONLYOFFICE Apps to HTTPS using the letsencrypt certificate, launch switching to HTTPS manually from the /app/onlyoffice/config/apps-ssl-setup file:
bash /app/onlyoffice/config/apps-ssl-setup user@example.com yourdomain.com
Where:
user@example.comis the email used for registration and recovery contact. Use comma to register multiple emails, for example: u1@example.com,u2@example.com.yourdomain.comis the address of the domain where your ONLYOFFICE Apps workspace is installed. Use comma to register multiple domains, for example: yourdomain1.com,yourdomain2.com.
The script will automatically create and install the letsencrypt.org CA-signed certificate to your server and restart the NGINX service for the changes to take effect.
Now your workspace should be available via the https:// address.
Using own certificates
If you want to switch an already installed ONLYOFFICE Apps to HTTPS using your own certificates, launch switching to HTTPS manually from the /app/onlyoffice/config/apps-ssl-setup file:
bash /app/onlyoffice/config/apps-ssl-setup -f yourdomain.com /app/onlyoffice/fullchain.pem /app/onlyoffice/privkey.pem
Where:
yourdomain.comis the address of the domain where your ONLYOFFICE Apps workspace is installed. Use comma to register multiple domains, for example: yourdomain1.com,yourdomain2.com./app/onlyoffice/fullchain.pemis the path to the certificate file for the domain./app/onlyoffice/privkey.pemis the path to the private key file for the certificate.
A self-signed certificate must have a full chain to work correctly.
