- Docs
- Configuration
- Community
- Docker version
- Adding fonts to ONLYOFFICE Docs Community Edition on Docker
Sometimes you might want to add additional fonts to ONLYOFFICE Docs to enhance the work with the editors. That can be done quite easily.
Bare-bones instructions
By default, ONLYOFFICE Docs uses embedded free fonts from the operating system where ONLYOFFICE Docs is installed.
The following font types are supported:
- TrueType:
.ttf,.tte - OpenType:
.otf,.otc,.ttf,.ttc - Web Open Font Format:
.woff,.woff2
If you would like to use additional fonts, you can do the following:
Check the
container idby running the following command:docker ps -
Copy the fonts to the
/usr/share/fonts/folder within the running container:docker cp font.crt container_id:/usr/share/fonts/ -
Go inside the container:
docker exec -it container_id bash - Open the /usr/bin folder. Run the
documentserver-generate-allfonts.shscript. - For ONLYOFFICE Docs 8.1.3 or earlier, please clear the browser cache and reopen the page. For later versions, this step is not required.
Helpful hints
During the installation process, ONLYOFFICE Docs will check the presence of the following font files in your computer's system: arial.ttf, calibri.ttf, cour.ttf, symbol.ttf, times.ttf, wingding.ttf. If these fonts are present, ONLYOFFICE Docs will include them in the list of available fonts.
When a document is opened for the first time, ONLYOFFICE Docs will check which fonts are present in the document, and will upload them from the computer with ONLYOFFICE Docs installation. In case the document contains fonts absent from the ONLYOFFICE Docs computer, it will upload the closest font substitute (the document layout and display might suffer from such substitution).
In case you want to limit the number of fonts uploaded from the system, you can do the following:
- delete fonts from the system and run the
documentserver-generate-allfonts.shscript, after that clear the browser cache and reopen the page (might ruin the original document layout and display); - limit the number of fonts in documents used (using only most spread fonts: Times New Roman, Verdana, Tahoma, etc.);
- use compression (dynamic and static).
