Artikel zum Thema:
Schließen
Schließen
Change application settings
To access the Spreadsheet Editor advanced settings,
  2. tap the arrow next to the Application Settings Application Settings menu item.
Currently, the following advanced settings are available:
  • UNIT OF MEASUREMENT - this option allows to specify what units are used for measuring elements parameters such as width, height, spacing, margins etc. You can select the Centimeter, Point, or Inch option.
  • FORMULA LANGUAGE - this option allows to select the language for displaying and entering formula names. Currently, the following formula languages are available: English, Deutsch, Spanish, French, Italian, Russian, Polish.
  • REGIONAL SETTINGS - this option allows to select the default display format for currency and date and time.
  • COMMENTING DISPLAY - this option allows to set, if you want to display Comments and/or Resolved Comments on the worksheet. If you enable these options, the commented cells will be marked on the sheet.
  • R1C1 Reference Style - this option allows to enable the R1C1 reference style instead of the A1 reference style used by default.
Schließen
