Artikel zum Thema:
Schließen
Schließen
Align data in cells
You can align your data within a cell horizontally and vertically. To do that:
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Cell option in the pop-up menu,
  3. tap the Open settings icon to the right of the Text format menu item Text Format section.
  4. select one of the horizontal or vertical alignment types:
    • Tap the necessary horizontal alignment type to apply it:
      • tap the Align Left Align Left icon menu item to line up the text by the left side of the cell (the right side remains unaligned).
      • tap the Align Center Align Center icon menu item to line up the text by the center of the cell (the right and the left sides remains unaligned).
      • tap the Align Right Align Right icon menu item to line up the text by the right side of the cell (the left side remains unaligned).
      • tap the Justified Justified icon menu item to line up the text by both the left and the right sides of the cell (additional spacing is added where necessary to keep the alignment).
    • Tap the necessary vertical alignment type to apply it:
      • tap the Align Top Align Top icon menu item to align your data to the top of the cell;
      • tap the Align Middle Align Middle icon menu item to align your data to the middle of the cell;
      • tap the Align Bottom Align Bottom icon menu item to align your data to the bottom of the cell.
Schließen
