Artikel zum Thema:
Schließen
Schließen
Apply font decoration styles
Select the text you want the formatting to be applied to and open the settings panel by:
Switch to the Text tab and use one of the available settings:
Text settings
Bold Bold - tap this icon to make the font bold giving it more weight.
Italic Italic - tap this icon to make the font italicized giving it some right side tilt.
Underline Underline - tap this icon to make the text underlined with the line going under the letters.
Strikethrough Strikethrough - tap this icon to make the text struck out with the line going through the letters.
Tap the Text advanced settings Additional Formatting menu item and use one of the following options:
  • Strikethrough is used to make the text struck out with the line going through the letters.
  • Double Strikethrough is used to make the text struck out with the double line going through the letters.
  • Superscript is used to make the text smaller and place it to the upper part of the text line, e.g. as in fractions.
  • Subscript is used to make the text smaller and place it to the lower part of the text line, e.g. as in chemical formulas.
  • Small Caps is used to make all letters lower case.
  • All Caps is used to make all letters upper case.
  • Letter Spacing is used to set the space between the characters. Tap Minus icon or Plus icon icons to decrease or increase the current value.
Schließen
