Artikel zum Thema:
Schließen
Schließen
Align your text in a text box
Select the text you want the alignment to be applied to and open the settings panel by:
  • tapping the Edit option in the pop-up menu.
Switch to the Text tab and swipe up to see all the settings.
Paragraph Alignment settings
Select the alignment type you would like to apply:
  • Apply the necessary horizontal alignment type:
    tap the Align Left icon to line up the text by the left side of the text box (the right side remains unaligned).
    tap the Align Center icon to line up the text by the center of the text box (the right and the left sides remains unaligned).
    tap the Align Right icon to line up the text by the right side of the text box (the left side remains unaligned).
    tap the Justified icon to line up the text by both the left and the right sides of the text box (additional spacing is added where necessary to keep the alignment).
  • Apply one of the vertical alignment types:
    tap the Align Top icon to align your text to the top of the text box;
    tap the Align Middle icon to align your text to the middle of the text box;
    tap the Align Bottom icon to align your text to the bottom of the text box.
Schließen
