Artikel zum Thema:
Schließen
Schließen
Manage slides
Create new slides
To create a new slide:
  • tap the Insert object icon at the top toolbar to open the new object insertion panel,
  • on the Slide tab, select a slide with the necessary layout.
    Note: you can change the layout of the added slide anytime. For additional information on how to do that refer to the Change slide layout section of this guide.
A new slide will be inserted after the selected one in the list of the existing slides on the left.
Duplicate slides
To duplicate a slide:
  1. tap the necessary slide in the list of the existing slides on the left,
  2. open the slide settings panel by
  3. swipe up and tap the Duplicate Slide button.
The duplicated slide will be inserted after the selected one in the slide list.
Move slides
To move an existing slide:
  1. touch and hold the necessary slide in the list of the existing slides on the left,
  2. without lifting your finger, drag the slide to the necessary place in the list (a horizontal line indicates a new location).
Delete slides
To delete an unnecessary slide:
  1. tap the slide you want to delete in the list of the existing slides on the left,
  3. swipe up and tap the Delete Slide button.
Schließen
