Artikel zum Thema:
Schließen
Schließen
Change paragraph indents
To change the first line offset from the left part of the page,
  1. put the cursor within the paragraph you need, or select several paragraphs or the whole text,
  2. open the text and paragraph settings panel by
  3. on the Text tab, use the respective icons: Decrease Indent Decrease Indent and Increase Indent Increase Indent,
    Paragraph Indent settings
Schließen
