Artikel zum Thema:
Schließen
Schließen
Apply formatting presets
To apply one of the available text formatting presets,
  1. place the cursor within the paragraph you need, or select several paragraphs you want to apply one of the formatting presets to,
  2. open the text and paragraph settings panel by
  3. switch to the Paragraph tab,
  4. select the preset you need from the PARAGRAPH STYLES list (swipe it up to see more styles).
    Paragraph Styles settings
    The following formatting presets are available: normal, no spacing, heading 1-9, title, subtitle, quote, intense quote, list paragraph, footer, header, footnote text.
Schließen
