Artikel zum Thema:
Schließen
Schließen
Manipulate objects
Resize objects
To change the autoshape/image/chart size, touch and drag one of the resize handles Resize handle situated on the object edges.
Move objects
To alter the autoshape/image position, touch and drag the object to the necessary position.
When you move an object, guide lines are displayed to help you position the object on the page precisely.
To move a table, touch and hold the Select table handle handle and drag the table to a different place in the document.
Rotate objects
To rotate the autoshape/image, touch the rotation handle Rotation Handle and drag it clockwise or counterclockwise.
Reshape autoshapes
When modifying some shapes, for example Figured arrows or Callouts, the yellow reshaping handle Yellow diamond icon is also available. It allows to adjust some aspects of the shape, for example, the length of the head of an arrow.
Selected autoshape
Arrange several objects
If you have several objects overlapped you can arrange their order:
  1. tap the necessary object to select it,
  2. tap the Edit object icon at the top toolbar,
  3. tap the Reorder menu item,
  4. select the desired arrangement option:
    Bring to Foreground Bring to Foreground - to move the selected object in front of all other objects,
    Send to Background Send to Background - to move the selected object behind all other objects,
    Move Forward Move Forward - to move the selected object by one level forward as related to other objects,
    Move Backward Move Backward - to move the selected object by one level backward as related to other objects.
Schließen
