Artikel zum Thema:
Schließen
Schließen
Select cell background color
To apply a background color to a certain cell/cell range or change the current one,
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the More option in the pop-up menu and choosing the Cell menu item,
  3. tap the Fill color option to open the color palette panel,
  4. select the necessary color on the Theme Colors or Standard Colors palette (swipe it up to see more colors),
    Cell Background settings
  5. close the cell settings panel by tapping the Close settings panel arrow on the right.
To clear the background color of a certain cell, use the No Fill No Fill icon on the Standard Colors palette.
Schließen
