Artikel zum Thema:
Schließen
Schließen
Insert tables
Insert a table
  1. place the cursor where you want the table to be put,
  3. the TABLE tab is activated by default. Select one of the available table templates. Each template combines certain formatting parameters, such as a background color, border style, row/column banding etc.
  4. in the Table Size window that opens, set the necessary Columns and Rows number (the 3 by 3 cell table is selected by default, you can specify up to 10 rows/columns),
  5. tap OK.
The table will be added. The insertion point is placed in the upper left cell so that you can start entering data. Tap within a different cell to place the insertion point in it.
Select, move and resize the table
To select an entire table, tap the Select table handle handle in its upper left corner.
Resize table
Touch and hold the Select table handle handle to drag the table to a different place in the document.
To change a row height, touch the corresponding Resize table handle handle located to the left of the table and drag it up or down.
To change a column width, touch the corresponding Resize table handle handle located above the table and drag it to the left or right.
Add or delete rows or columns
  1. tap a cell within the necessary row/column,
  2. open the text/object settings panel by
  3. switch to the TABLE tab,
  4. use the corresponding icons:
    Add column left - to insert a column at the left side from the column where the cursor is placed.
    Add column right - to insert a column at the right side from the column where the cursor is placed.
    Add row above - to insert a row above the row where the cursor is placed.
    Add row below - to insert a row below the row where the cursor is placed.
    Remove column - to remove the column where the cursor is placed.
    Remove row - to remove the row where the cursor is placed.
Adjust the table settings
  1. select the table by tapping on it,
  4. swipe up and tap the the necessary menu item: Table Options, Style or Wrap. Use the Return icon on the left to return to the previous settings section.
    The Table Options section contains the following options:
    • Repeat as Header Row - is used to insert the same header row at the top of each page in long tables.
    • Resize to Fit Contents - enables automatic change of each column width in accordance with the text within its cells.
    • Cell Margins - the space between the text within the cells and the cell border used by default. The value can be altered by dragging the slider.
      Table Options
    • STYLE - to change the selected preformatted table template. Swipe up to see more templates.
      Style Options
      Style Options - tap this menu item to use the options that allow to emphasize certain rows/columns applying a specific formatting to them, or highlight different rows/columns with the different background colors to clearly distinguish them.
      • Header Row - emphasizes the topmost row in the table with a special formatting,
      • Total Row - emphasizes the bottommost row in the table with a special formatting,
      • Banded Row - enables the background color alternation for odd and even rows,
      • First Column - emphasizes the leftmost column in the table with a special formatting,
      • Last Column - emphasizes the rightmost column in the table with a special formatting,
      • Banded Column - enables the background color alternation for odd and even columns.
    • FILL - to choose a solid color for the table background. Select the necessary color on the Theme Colors or the Standard Colors palette,
      Fill Options
    • BORDER - to set the border Size by dragging the slider, select its Color on the palette and choose the way it will be displayed in the cells by tapping one of the the icons:
      Border Type
  5. Close the table settings panel by tapping the Close settings panel arrow on the right.
Remove the table
  1. select the table by tapping the Select table handle handle in its upper left corner,
    • tapping the More option in the pop-up menu and choosing the Edit menu item,
  4. tap the REMOVE TABLE button.
Schließen
