Articles with the tag:
Close
Close
Try in the cloud
Connecting Selectel Cloud Storage to ONLYOFFICE DocSpace
Connect the Selectel Cloud Storage service to use the connected cloud storage as a third-party storage when creating backups.
Creating authorization keys
You will have to setup authorization keys for Selectel Cloud Storage. Follow these steps:
  1. Sign in to your Selectel account;
  2. Go to the Cloud storage -> Users section;
  3. Choose the user who has corresponding access rights to the storage or create a new user providing him/her with Read and write access to the containers which will be used to store your backups;
  4. Copy the user login and enter it in the Selectel authUser field on the portal;
  5. Copy the user password and enter it in the Password to access the storage field on the portal.
  1. Click the Options icon menu in the lower left corner and select the Settings option.
  3. In the Third-party services section, click the sliding button to the right of the Selectel Cloud Storage logo.
  4. Enter your keys and click the Connect button.
To store your DocSpace data backup in Selectel Cloud Storage,
  1. Go to the 'Backup' section (DocSpace Settings -> Backup -> Third-party storage).
  2. Select Selectel Cloud Storage as the desired storage.
  3. Specify the necessary parameters and click the 'Create copy' button.
You Might Also Like This:
Close
