Articles with the tag:
Close
Close
Change text orientation
To change text orientation,
Curently, this function is not available when editing a local spreadsheet using the On Device section
  1. select a cell, a range of cells or the whole worksheet,
  2. open the Cell settings panel by
    • tapping the Cell option in the pop-up menu,
  3. tap the Open settings arrow to the right of the Text Orientation Text Orientation section to open the text orientation menu.
  4. choose the option that fits the text most:
    • Tap the necessary horizontal alignment type to apply it:
      • Angle Counterclockwise icon Angle Counterclockwise will orientate the text at an angle and upwards,
      • Angle Clockwise icon Angle Clockwise will orientate the text at an angle and downwards,
      • Vertical Text icon Vertical Text will orientate the text with each character taking up one line,
      • Rotate Text Up icon Rotate Text Up will orientate the text with each character’s top point facing left,
      • Rotate Text Down icon Rotate Text Down will orientate the text with each character’s top point facing right.
    • To reverse all orientation changes, repeat steps 1-3 and choose option Justified icon Horizontal Text.
You Might Also Like This:
Close
