Articles with the tag:
Close
Close
Insert column breaks
When editing a document that has a multi-column layout, you can specify where a new column should start.
To insert a column break at the current cursor position,
  1. tap the Insert object icon at the top toolbar to open the new object insertion panel,
  2. switch to the Other tab tab,
  3. select the Break Break option,
  4. choose the Column Break Column Break option.
To remove the added column break, place the cursor at the beginning of the text that followed it and press the Backspace key key on the on-screen keyboard.
You Might Also Like This:
Close
