Fermer
Fermer
Centre d'aide
Control Panel
Receiving audit trail data
Control Panelv.2.9 ONLYOFFICE Control Panel changelog
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
The Audit Trail section of the Control Panel allows you to browse through the list of the latest changes (creation, modification, deletion etc.) made by users to the entities (tasks, opportunities, files etc.) on your portal.
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Viewing audit trail data
Switch to the Control Panel within the necessary portal and open the Audit Trail page in the PORTAL SETTINGS section on the left sidebar.
This feature is currently available for the Common section of the Documents module, Projects, CRM and People modules, as well as for portal settings.
This page displays only the last 20 records. Each record shows which action took place, who performed it and when the event occurred. You can also set the period to store the data. By default, it is set to 180 days.
Receiving audit trail data Receiving audit trail data
To view the detailed statistics for the latest half year click the Download and open report button. The report will open in an .xlsx spreadsheet (AuditTrail_ReportStartDate-EndDate.xlsx).
The file will also be automatically saved to the My documents section.
The audit trail report includes the following details: user IP address, Browser and Platform which were being used when the registered event occurred, Date and time of the event, name of the User who performed the operation, portal Page where the action has been performed, generic Action Type (for example, download, attach, updated access), specific Action (for example, Projects [Product development and promotion]. Tasks [Distribute coupons]. Status Updated: Closed ), Product and Module that the changed entity is referred to.
The records are sorted chronologically in descending order, but you can easily sort and filter the data by any parameter or use the search tool to quickly find a specific record.
Docker, Windows and Linux
Cela peut vous aider aussi :
Fermer
