You can change a slide size for all the slides in the presentation, as well as specify which color scheme you want to use.
To access the current presentation settings,
- tap the
Tools icon in the right corner of the top toolbar,
- tap the arrow next to the
Presentation Settings menu item.
Currently, the following presentation settings are available:
- SLIDE SIZE - this option allows to select one of the available presets: Standard (4:3) or Widescreen (16:9).
- Color Scheme - is used to select the necessary Color Scheme. It allows to change the default color palette for slide elements (font, background, autoshapes and charts).
