Schließen Hilfe-Center ONLYOFFICE Mobile web editors for iOS Presentation Editor Document Editor vollständige Dokumentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents for Android ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors ONLYOFFICE Mobile web editors for iOS Overview Manage files Open or create new files and folders Share files and folders Document Editor Grundfunktionen Navigate through your document Select, cut, copy, paste text Undo/redo your actions Seitenparameter festlegen Set page parameters Insert page breaks Insert column breaks Insert section breaks Insert page numbers Insert footnotes Absatzformatierung Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Textformatierung Set font type, size, and color Apply font decoration styles Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Adjust chart settings Change text wrapping Manipulate objects Werkzeuge und Einstellungen Collaborative document editing Spell-checking Use the Find and Replace function Change application settings Macros settings Download and print your document View document information Spreadsheet Editor Grundfunktionen Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Freeze panes Operationen mit Tabellenblätter Create or delete sheets Manage existing sheets Zellformatierung Set font type, size, and color Add hyperlinks Bearbeiten von Zelleigenschaften Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Bearbeiten von Zeilen und Spalten Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Objekte bearbeiten Insert charts Insert images Insert formulas Insert autoshapes Manipulate objects Werkzeuge und Einstellungen Collaborative spreadsheet editing Use the Find and Replace function Change spreadsheet settings Change app settings Macros settings Download and print your spreadsheet View spreadsheet information Presentation Editor Grundfunktionen Mobile presentation viewer Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Folien bearbeiten Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Textformatierung Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Change text indents Set paragraph line spacing Create lists Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Adjust chart settings Manipulate objects Werkzeuge und Einstellungen Collaborative presentation editing Spell-checking Use the Find and Replace function Change presentation settings Change application settings Macros settings Download your presentation Print your presentation View presentation information ONLYOFFICE Mobile web editors for Android Glossar Video Häufig gestellte Fragen Allgemeines Technologie Preise Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Create lists Formatierung des Absatzes Absatzeinzüge ändern Zeilenabstand in Absätzen festlegen Initialbuchstaben einfügen Seitenumbrüche einfügen Rahmen hinzufügen Textformatierung übernehmen/entfernen Tabstopps setzen Text in einem Absatz ausrichten More articles Gliederungsebene konfigurieren Hintergrundfarbe für einen Absatz festlegen Text im Absatz ausrichten Formatierungsvoreinstellungen anwenden Hintergrundfarbe für einen Absatz auswählen Absatzeinzüge ändern Absatzzeilenabstand einstellen Zeilenumbrüche einfügen Listen erstellen Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Change text indents Set paragraph line spacing Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Align text in a text box Change text indents Set paragraph line spacing Create lists Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Align text in a text box Change text indents Set paragraph line spacing Create lists Creating a hanging indent Listen erstellen Listen erstellen Nummerierte Listen erstellen Listen erstellen Create lists Create lists Create lists Create lists Create lists More articles Create lists Create lists Formatierung der Liste Listen erstellen Nummerierte Listen erstellen Listen erstellen Create lists Create lists Create lists Create lists Create lists More articles Create lists Create lists To create a list in a text box, place the cursor to the position where a list will be started (this can be a new line or the already entered text), open the settings panel by tapping the icon at the top toolbar, or tapping the Edit option in the pop-up menu, switch to the Text tab and swipe up to see all the settings, select the list type you would like to start: tap the Bullets option to create an Unordered list with markers and select the marker type, tap the Numbers option to create an Ordered list with digits or letters and select how the list is going to look like. now each time you press the Enter key at the end of the line a new ordered or unordered list item will appear. To stop that, tap the key and continue with the common text paragraph. You can also change the text indentation in the lists using the Decrease Indent and Increase Indent icons on the Text tab. Power up your iOS Create, edit and view documents, spreadsheets and presentations of all popular formats Wer sich dafür interessiert hat, hat auch das Folgende gelesen: Schließen
