Schließen Hilfe-Center ONLYOFFICE Documents for Android Spreadsheet Editor Document Editor vollständige Dokumentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Grundfunktionen Navigate through your document Select, cut, copy, paste text Undo/redo your actions Seitenparameter festlegen Set page parameters Insert section breaks Insert page numbers Absatzformatierung Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Textformatierung Set font type, size, and color Apply font decoration styles Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Grundfunktionen Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operationen mit Tabellenblätter Create or delete sheets Manage existing sheets Zellformatierung Set font type, size, and color Add hyperlinks Bearbeiten von Zelleigenschaften Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Bearbeiten von Zeilen und Spalten Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Objekte bearbeiten Insert images Insert formulas Insert autoshapes Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Grundfunktionen Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Folien bearbeiten Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Textformatierung Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossar Video Häufig gestellte Fragen Allgemeines Technologie Preise Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Select cell background color Formatierung der Zelle Fügen Sie einen Rahmen hinzu Richten Sie die Daten in den Zellen aus Löschen Sie den Text, das Format in einer Zelle Vereinigen Sie die Zellen Select cell background color Add cell borders Apply cell style Align data in cells More articles Wrap text in a cell Merge cells Change number format Apply table styles Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Merging cells Wrapping text in excel Hintergrund der Elemente Farbschema ändern Objekte ausfüllen und Farben auswählen Tabellen einfügen und formatieren AutoFormen einfügen Tabellen einfügen Hintergrundfarbe für einen Absatz festlegen Bestimmen Sie die Schriftart, -größe, Farben und Stil Folienparameter festlegen More articles Hintergrundfarbe für einen Absatz auswählen Tabellen einfügen Select cell background color Change slide background Insert tables Select background color for a paragraph Insert tables Select cell background color Change slide background Insert tables Select background color for a paragraph Insert tables Select cell background color Change slide background Insert tables Select background color for a paragraph Insert tables Select cell background color Change slide background Insert tables Farbe ändern Assigning a color to your calendar Bestimmen Sie die Schriftart, -größe, Farben und Stil Schriftart, -größe und -farbe festlegen AutoFormen einfügen Objekte ausfüllen und Farben auswählen Hintergrundfarbe für einen Absatz festlegen Zuordnung einer Farbe Ihrem Kalender Hintergrundfarbe für einen Absatz auswählen More articles Schriftart, -größe und -farbe einstellen Tabellen einfügen Set font type, size, and color Select cell background color Add cell borders Insert autoshapes Set font type, size, color Insert tables Select background color for a paragraph Set font type, size, and color Insert tables Set font type, size, and color Select cell background color Add cell borders Insert autoshapes Set font type, size, and color Insert tables Insert tables Set font type, size, and color Select cell background color Add cell borders Insert autoshapes Set font type, size, color Insert tables Select background color for a paragraph Set font type, size, and color Insert tables Set font type, size, and color Select cell background color Add cell borders Insert autoshapes Set font type, size, color Insert tables To apply a background color to a certain cell/cell range or change the current one, select a cell, a range of cells or the whole worksheet, open the Cell settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu and choosing the Cell menu item, tap the Fill color option to open the color palette panel, select the necessary color on the Theme Colors or Standard Colors palette, close the fill color settings panel by tapping the arrow on the left. To clear the background color of a certain cell, use the No Fill icon on the Standard Colors palette. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Wer sich dafür interessiert hat, hat auch das Folgende gelesen: Schließen
