Schließen Hilfe-Center ONLYOFFICE Documents for Android Spreadsheet Editor Document Editor vollständige Dokumentation User guides ONLYOFFICE Workspace ONLYOFFICE Groups ONLYOFFICE Docs Mail Server Talk Module ONLYOFFICE Groups Documents Module People Module Commmunity Module CRM Module Projects Module Mail Module Calendar Module ONLYOFFICE Docs Document Editor Spreadsheet Editor Presenetation editor ONLYOFFICE Mobile Apps ONLYOFFICE Documents for iOS ONLYOFFICE Documents app for Android Overview Changelog Manage files Open or create new files and folders Share files and folders Document Editor Grundfunktionen Navigate through your document Select, cut, copy, paste text Undo/redo your actions Seitenparameter festlegen Set page parameters Insert section breaks Insert page numbers Absatzformatierung Align your text in a paragraph Apply formatting presets Select background color for a paragraph Change paragraph indents Set paragraph line spacing Create lists Textformatierung Set font type, size, and color Apply font decoration styles Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Change text wrapping Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Download and print your document View document information Spreadsheet Editor Grundfunktionen Navigate through your spreadsheet Select, cut, copy, paste data Undo/redo your actions Operationen mit Tabellenblätter Create or delete sheets Manage existing sheets Zellformatierung Set font type, size, and color Add hyperlinks Bearbeiten von Zelleigenschaften Select cell background color Add cell borders Apply cell style Align data in cells Wrap text in a cell Merge cells Change number format Bearbeiten von Zeilen und Spalten Remove rows/columns Hide or show rows/columns Resize rows/columns Sort and filter data Objekte bearbeiten Insert images Insert formulas Insert autoshapes Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change spreadsheet settings Download and print your spreadsheet View spreadsheet information Presentation Editor Grundfunktionen Navigate through your presentation Select, cut, copy, paste text and objects Undo/redo your actions Folien bearbeiten Manage slides Set slide parameters Change presentation theme Change slide layout Apply transitions Change slide background Preview your presentation Textformatierung Insert text Set font type, size, and color Apply font decoration styles Align your text in a text box Set paragraph line spacing Create lists Add hyperlinks Objekte bearbeiten Insert tables Insert autoshapes Insert images Manipulate objects Werkzeuge und Einstellungen Use the Find and Replace function Change presentation settings Download your presentation Print your presentation View presentation information ONLYOFFICE Projects for iOS ONLYOFFICE Web Editors Glossar Video Häufig gestellte Fragen Allgemeines Technologie Preise Workspace Enterprise Edition Docs Enterprise Edition Docs Developer Edition ONLYOFFICE Groups Connectors Apply cell style Formatierung der Zelle Fügen Sie einen Rahmen hinzu Richten Sie die Daten in den Zellen aus Löschen Sie den Text, das Format in einer Zelle Vereinigen Sie die Zellen Select cell background color Add cell borders Apply cell style Align data in cells More articles Wrap text in a cell Merge cells Change number format Apply table styles Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Select cell background color Add cell borders Apply cell style Align data in cells Change text orientation Wrap text in a cell Merge cells Change number format Merging cells Wrapping text in excel vordefinierte Stile Formatvorlagen anwenden Tabellen einfügen und formatieren Tabellen einfügen Folienparameter festlegen Sortieren und filtern Sie die Daten Inhaltsverzeichnis erstellen Pivot-Tabellen erstellen und bearbeiten Tabellenvorlage formatieren Datenschnitte in den formatierten Tabellen erstellen More articles Formatierungsvoreinstellungen anwenden Apply cell style Apply table styles Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme Apply formatting presets Apply cell style Change presentation theme You can apply one of the formatting presets selecting the cell you wish to format and choosing the desired preset: select a cell, a range of cells or the whole worksheet, open the Cell settings panel by tapping the icon at the top toolbar, or tapping the option in the pop-up menu and choosing the Cell menu item, swipe up to see the Cell Styles palette and tap the style you want to apply. close the cell settings panel by tapping the arrow on the right. Download Teach your robot to read View documents, spreadsheets and presentations of all popular formats Wer sich dafür interessiert hat, hat auch das Folgende gelesen: Schließen
