To apply one of the available text formatting presets,
- place the cursor within the paragraph you need, or select several paragraphs you want to apply one of the formatting presets to,
- open the text and paragraph settings panel by
- tapping the
icon at the top toolbar, or
- tapping the
option in the pop-up menu,
- switch to the PARAGRAPH tab,
- select the preset you need from the Paragraph styles list (swipe it up to see more styles),
The following formatting presets are available: caption, normal, no spacing, heading 1-9, title, subtitle, quote, intense quote, list paragraph, footer, header, footnote text.
- close the paragraph settings panel by tapping the
arrow on the right.
