Systemsteuerung
v3.5
ONLYOFFICE Systemsteuerung: Änderungsprotokoll
Version 3.5
Release date: 03/14/2023
- Changed API methods for migration, implemented progressQueue.
- Changed settings for connecting third-party storages. Added tooltips for fields. Added the 'Server Side Encryption Method' block for Amazon AWS S3.
- Added logos for dark theme in the Branding section. Logos for the About page are now separate fields in the Advanced tab.
- Added the ability to set the portal memory quota.
Version 3.1.1
Release date: 08/08/2022
- Fixed issue with file indexing.
- Fixed elasticsearch container errors when updating ONLYOFFICE Groups.
- Fixed issue with brand logos after updating in the Docker installation.
- Fixed texts and layout for the Migration feature.
Version 3.1
Release date: 05/25/2022
- Fixed bugs.
Version 3.0
Release date: 06/07/2021
Version 2.9.1
Release date: 12/10/2020
Version 2.9
Release date: 10/14/2020
- Updated
node.js
, updated packages (transition to samlify
for SSO);
- Added the
upgrade
page with a proposal to upgrade to Enterprise Edition;
- Added the
activate
page with a possibility to upload a license file;
- Transition to the new
samlify
library;
Version 2.7
Release date: 04/25/2019
Version 2.5.1
Release date: 04/07/2018
- Fixed the
Server internal error
error when using the groups enclosed inside each other in the AD (bug #37414).
Version 2.4.0
Release date: 01/13/2018
- Fixed the
Invalid ssoConfig
error which occurred when the link to the IdP contained the question mark '?', e.g.: IdP Single Sign-On Endpoint URL: https://accounts.google.com/o/saml2/idp?idpid=777777
- Fixed the
Invalid authentication token
error which prevented from adding a user to the portal using the AD FS, in case the +
or -
characters were present when sending the encrypted data.
Version 2.3.0
Release date: 12/15/2017
Audit Trail
heading was present at the login history page (bug #36026);
- Fixed the bug with the
LDAP Domain not found
error which occurred if the DN record had no DC records (the users with Sun/Oracle DS were affected); now if the LDAP domain could not be specified, the LDAP domain will acquire the unknown
value or the ldap.domain
value from the web.appsettings.config
configuration file;
Sizelimit Exceeded
error when trying to get more than 1000 users from the Active Directory;
- Added additional logging;
Mail Attribute
Version 2.2.0
Release date: 10/31/2017
- Added the
documentserver-prepare4shutdown.sh
script launch when updating the document-server for the correct edited document saving.
- Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
- Added the new
sso.auth
service;
Version 2.0.0
Release date: 05/25/2017
MVC
to Node.js
Version 1.6.0
Release date: 12/05/2016
- Added new translations;
- Bug fixes.
Mit der Branding-Funktion der Systemsteuerung können Sie ganz einfach Branding-Elemente ersetzen, die in der Online-Office-Benutzeroberfläche verwendet werden, und das Erscheinungsbild des Portals an Ihre Unternehmensmarke anpassen:
- Ihren Firmennamen in den Textelementen wie Tooltips, Messageboxen usw. verwenden,
- ersetzen Sie das Standard-Favicon und -Logos durch Ihr eigenes Logo,
- die im Fenster Über dieses Programm angezeigten Informationen ändern,
- Verbergen oder Anzeigen von Links zu externen Ressourcen wie Feedback- und Support-Formularen, Hilfecenter usw.
Branding-Einstellungen können auf alle Portale oder nur auf das aktuelle Portal angewendet werden.
Um auf die Systemsteuerung zuzugreifen, melden Sie sich in Ihrem Portal an und klicken Sie auf der Startseite auf den Link "Systemsteuerung". Sie können auch in den “Einstellungen” des Portals auf den Link „Systemsteuerung“ im linken Bereich klicken.
Branding-Elemente für alle Portale ändern
Im Abschnitt ALLGEMEIN können Sie die Einstellungen für alle Ihre Portale ändern.
Öffnen Sie die Seite im Abschnitt ALLGEMEIN in der linken Seitenleiste. Sie können grundlegende und erweiterte Branding-Einstellungen ändern.
Grundlegende Branding-Einstellungen ändern
Die Registerkarte STANDARD wird standardmäßig geöffnet. Hier können Sie den Firmennamen ändern und Logos ersetzen.
- Geben Sie Ihren Firmennamen in das Texteingabefeld ein, um alle Titel und Nachrichten in der Online-Office-Oberfläche, in der der Standardwert verwendet wird, durch den von Ihnen angegebenen zu ersetzen. Klicken Sie unterhalb des Eingabefeldes auf die Schaltfläche Verwenden als Logo, wenn Sie Ihren Firmennamen als Textlogo (anstelle eines Bildlogos) verwenden möchten - alle untenstehenden Logos ändern sich entsprechend.
- Ersetzen Sie alle Bild-Logos, die im Online-Office erscheinen:
Wir empfehlen, Bilder im PNG-Format mit transparentem Hintergrund zu verwenden. Um die Lesbarkeit Ihrer Logos zu verbessern und ihre Konturen deutlich unterscheidbar zu machen, müssen Sie sie auch für die Verwendung auf dunklen oder hellen Hintergründen optimieren. Die Bildgrößen werden für die Retina-Displays angezeigt. Bei Displays mit Standardauflösungen wird die Logobreite und -höhe beim Hochladen entsprechend angepasst.
- Logo für Kopfzeile der Editoren (172x40) (nur für die kostenpflichtige Serverversion verfügbar): - Dieses Logo erscheint in der oberen linken Ecke des gestarteten Online-Editors. Das erste, zweite und dritte Logo werden entsprechend für Dokumenten-, Präsentationseditor und Tabellenkalkulation verwendet, wenn das helle Thema aktiviert ist. Das vierte Logo wird für alle Editoren verwendet, wenn das dunkle Thema aktiviert ist.
- Logo für die Kopfzeile von Editoren - Eingebetteter Modus (172x40): Dieses Logo erscheint in der oberen linken Ecke Ihrer in Webseiten eingebetteten Portaldokumente.
- Logo für Kopfzeile der Editoren (172x40): Dieses Logo erscheint in der oberen linken Ecke der geöffneten Online-Editoren.
- Logo für die Anmeldeseite - helles Thema (432x70): Dieses Logo erscheint auf der Anmeldeseite des Portals und wird verwendet, wenn das helle Thema aktiviert ist.
- Logo für die Anmeldeseite - dunkles Thema (432x70): Dieses Logo erscheint auf der Anmeldeseite des Portals und wird verwendet, wenn das dunkle Thema aktiviert ist.
- Favicon (32x32): Dieses Logo wird in der Adressleiste oder Registerkarte eines Webbrowsers angezeigt, wenn das Portal darin geöffnet wird, oder im Lesezeichenbereich, wenn Sie die Portaladresse zu den Lesezeichen hinzugefügt haben.
Klicken Sie rechts neben dem Logo, das Sie ersetzen möchten, auf den Link Logo ändern. Suchen Sie im Explorer-Fenster nach der erforderlichen Bilddatei und klicken Sie auf die Schaltfläche Öffnen. Das Bild wird geladen und im entsprechenden Logo-Feld angezeigt.
- Klicken Sie unten auf die Schaltfläche Speichern, damit die von Ihnen festgelegten Parameter aktualisiert werden.
Um zu den Standardeinstellungen zurückzukehren, klicken Sie auf die Schaltfläche Auf Standard setzen.
Erweiterte Branding-Einstellungen ändern
Wechseln Sie zur Registerkarte ERWEITERT auf der Seite Branding im Abschnitt ALLGEMEIN. Hier können Sie die im Fenster Über dieses Programm angezeigten Informationen ändern und Links zu externen Ressourcen ausblenden.
Der Abschnitt Einstellungen Unternehmens-Informationen wird verwendet, um Ihre Unternehmensinformationen anzugeben, die im Fenster Über dieses Programm im Portal und auf der Seite Über in den Online-Editoren angezeigt werden.
- Ersetzen Sie das Logo für die Info-Seite:
- Logo für die Info-Seite - helles Thema (432x70): Dieses Logo erscheint auf der Info-Seite des Portals (Benutzerprofil -> Über dieses Programm) und auf der Info-Seite in den Online-Editoren und wird verwendet, wenn das helle Thema ermöglicht ist.
- Logo für die Info-Seite - dunkles Thema (432x70) Dieses Logo erscheint auf der Info-Seite des Portals (Benutzerprofil -> Über dieses Programm) und auf der Info-Seite in den Online-Editoren und wird verwendet, wenn das dunkle Thema ermöglicht ist.
- Geben Sie Ihren Firmennamen, Ihre E-Mail-Adresse, Telefonnummer, Website-URL-Adresse und Postanschrift in die entsprechenden Felder ein.
- Klicken Sie unten in diesem Abschnitt auf die Schaltfläche SPEICHERN.
Der Abschnitt Zusätzliche Ressourcen wird verwendet, um auszuwählen, ob Sie Links zu zusätzlichen Ressourcen in allen Portalmodulen und Beispieldokumente im Modul Dokumente anzeigen möchten.
- Deaktivieren Sie die Elemente, die Sie ausblenden möchten, und lassen Sie die Elemente aktiviert, die Sie anzeigen möchten:
- Feedback & Support Link anzeigen wird verwendet, um den Link zum Feedback- und Support-Formular zu verbergen oder anzuzeigen, das verwendet wird, um das ONLYOFFICE-Supportteam zu kontaktieren.
- Beispieldokumente anzeigen wird verwendet, um Beispieldokumente im Modul Dokumente auszublenden oder anzuzeigen.
- Link zu Video-Anleitungen anzeigen wird verwendet, um den Link zur Webseite mit den Trainingsvideos auszublenden oder anzuzeigen.
- Link zum Hilfe-Center anzeigen wird verwendet, um den Link zur Hilfe-Center-Seite auszublenden oder anzuzeigen.
Branding-Elementen für das aktuelle Portal ändern
Im Abschnitt PORTAL-EINSTELLUNGEN können Sie nur die Einstellungen für das aktuelle Portal ändern.
Wechseln Sie innerhalb des erforderlichen Portals zur Systemsteuerung und öffnen Sie die Seite Branding im Abschnitt PORTAL-EINSTELLUNGEN in der linken Seitenleiste.
Hier können Sie grundlegende Branding-Einstellungen für Ihr aktuelles Portal ändern. Die Einstellungen ähneln denen auf der Registerkarte STANDARDEINSTELLUNGEN im Abschnitt ALLGEMEIN. Erweiterte Branding-Einstellungen sind für das aktuelle Portal nicht verfügbar und können nur für alle Portale geändert werden.
