Artikel zum Thema:
Schließen
Schließen
Hilfe-Center
Control Panel
Branding your online office
Control Panelv.2.9 ONLYOFFICE Control Panel changelog
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
With the Branding feature provided by the Control Panel, you can easily replace branding elements used in the online office interface and customize the look of the portal according to your company brand:
  • use your company name in the text elements, such as tooltips, message boxes etc.,
  • replace the default favicon and logos with your own logo,
  • change the information displayed in the About this program window,
  • hide or show links to external resources, such as Feedback and Support form, Help Center etc.
Branding settings can be applied to all portals or to the current portal only.
To access Control Panel, sign in to your portal and click the 'Control Panel' link on the Start Page. Alternatively, you can go to the portal 'Settings' and click the 'Control Panel' link on the left-side panel.
Changing branding elements for all portals
The COMMON SETTINGS section allows you to change settings for all your portals.
Open the Branding page in the COMMON SETTINGS section on the left sidebar. You can change basic and advanced branding settings.
Changing basic branding settings
The BASIC tab is opened by default. Here you can change the company name and replace logos.
Branding page Branding page
  1. Enter your Company name in the text entry field to change all the titles and messages in the online office interface where the default value is used replacing it with the one you specified. Click the USE AS LOGO button to the right of the entry field if you want to use your company name as a text logo (instead of an image logo) - all the logos below will change correspondingly.
  2. Replace all the image Logos which appear in the online office:
    We recommended that you use images in the PNG format with a transparent background. To improve your logos legibility and make their outline clearly distinguishable, you also need to optimize them for use on dark or light backgrounds. The image sizes must strictly correspond to the sizes specified next to each logo.
    • Logo for the editor headers (172x40) (available for the paid server version only) - this logo appears in the upper left corner of the online editors launched.
    • Logo for the portal header (284x46) - this logo appears in the upper left corner of every portal page.
    • Logo for the About/Login page and editor embedded mode (432x70) - this logo appears on the Sign In page of the portal, the About page (user profile -> About this program) and in the upper left corner of your portal documents embedded into web pages.
    • Favicon (32x32) - this logo appears in the address bar or tab of a web browser when the portal is opened in it, or on the bookmarks panel if you've added the portal address to the bookmarks.
    Click the CHANGE button to the right of the logo you want to replace. In the window that opens, browse for the necessary image file and click the Open button. The image will be loaded and displayed in the corresponding Logo field.
  3. click the SAVE button at the bottom of the page to make the parameters you set take effect.
    Branding - saving Branding - saving
To return to the default settings, click the RESTORE DEFAULT button.
Changing advanced branding settings
Switch to the ADVANCED tab of the Branding page in the COMMON SETTINGS section. Here you can change the information displayed in the About this program window and hide links to external resources.
The Company info settings section is used to specify your company information displayed in the About this program window.
Advanced branding settings Advanced branding settings
  1. Enter your company name, email address, phone number, website URL address and postal address into the corresponding fields.
  2. Click the SAVE button at the bottom of this section.
The Additional resources section is used to choose if you want to display links to additional resources in all portal modules and sample documents in the Documents module.
  1. Uncheck the elements you want to hide and leave checked the ones you want to display:
    • Show Feedback & Support link - is used to hide or show the link to the Feedback and Support form which is used to contact ONLYOFFICE support team.
    • Show sample documents - is used to hide or show sample documents in the Documents module.
    • Show link to Video Guides - is used to hide or show the link to the web page containing training videos.
    • Show link to Help Center - is used to hide or show the link to the Help Center page.
Changing branding elements for the current portal
The PORTAL SETTINGS section allows you to change settings for the current portal only.
Switch to the Control Panel within the necessary portal and open the Branding page in the PORTAL SETTINGS section on the left sidebar.
Сurrent portal branding settings Сurrent portal branding settings
Here you can change basic branding settings for your current portal. The settings are similar to those contained in the BASIC settings tab within the COMMON SETTINGS section. Advanced branding settings are not available for the current portal and can be changed for all portals only.
Docker, Windows and Linux
Schließen
