Articles with the tag:
Close
Close
Try in the cloud
Try in the cloud
Help Center
Control Panel
Protect data using encryption
Version 3.5.2
Release date: 02/29/2024
General
  • Edited sources build.
Version 3.5
Release date: 03/14/2023
General
Version 3.1.1
Release date: 08/08/2022
General
Version 3.1
Release date: 05/25/2022
General
  • Fixed bugs.
Version 3.0
Release date: 06/07/2021
Update
Search
LoginHistory and AuditTrail
  • New empty screens added.
Restore
SSO
Version 2.9.1
Release date: 12/10/2020
Bug fixes
Version 2.9
Release date: 10/14/2020
General
LDAP
Single Sign-on
Version 2.7
Release date: 04/25/2019
LDAP
Version 2.5.1
Release date: 04/07/2018
LDAP
Single Sign-on
Version 2.4.0
Release date: 01/13/2018
Single Sign-on
Version 2.3.0
Release date: 12/15/2017
General
LDAP
  • Added additional logging;
Version 2.2.0
Release date: 10/31/2017
General
LDAP
Single Sign-on
  • Added the AD FS support;
Version 2.1.0
Release date: 07/03/2017
HTTPS
Single Sign-on
Version 2.0.0
Release date: 05/25/2017
General
Version 1.6.0
Release date: 12/05/2016
LDAP
  • Added new translations;
  • Bug fixes.
Version for Windows
Introduction
The Encrypt data at rest feature provided by the Control Panel allows you to ensure the security of sensitive data on your portal.
Encryption is a reversible conversion of information in order to maintain the confidentiality of the data stored on disk. Thus, even if intruders managed to gain access to the data stored on the hard disk, they will not be able to read it, since it is encrypted.
Encryption is based on a Encrypt-then-MAC type of encryption (AES-256-CBC + HMAC-SHA256) of the entire body of data within the ONLYOFFICE instance and is compliant with AES-256 international data encryption standard. AES-256 encryption type with CipherMode.CBC symmetric algorithm are used for enciphering the data on the portal, while SHA256 hashing function paired with HMAC message authentication code screening verify the integrity and the authenticity of the encrypted data.
This feature is available only for server versions.
Prepare for the encryption process
Before starting the encryption procedure, you must perform some preliminary steps.
  1. Manually stop the services that make changes to the files stored on disk.
    For Docker (within the CommunityServer container):
    systemctl stop onlyofficeMail*
    systemctl stop onlyofficeThumbnailBuilder.service
    For Linux:
    sudo service onlyofficeMail* stop
    sudo service onlyofficeThumbnailBuilder stop
    For Windows:
    Go to Control Panel -> Administrative Tools -> Services and stop the following services: ONLYOFFICE Mail Watchdog, ONLYOFFICE Mail Imap, ONLYOFFICE Mail Cleaner, ONLYOFFICE Mail Aggregator, ONLYOFFICE Thumbnail Builder. To do that, right click the service and choose Stop.
  2. Sign in to your portal and click the Control Panel icon on the Start Page. Alternatively, you can go to the portal Settings and select the Control Panel link on the left-side panel.
  3. Switch to the Backup section and backup data.
  4. Disable the Automatic Data Backup feature.
  5. Select the Local storage option for both Connect storage for static data and Connect storage as CDN.
    The Encrypt data at rest feature works only with local storage.
  6. Make sure there is enough space on your hard drive.
After the preliminary preparations are ready, you can proceed to the next step.
Encrypt storage
  1. Switch to the Storage section in the Control Panel.
  2. Check the Notify users that the portal will be unavailable checkbox to notify all active users via email when the encryption process starts.
    Upon the successful completion of the encryption process, all active users will also receive email notifications. If an error occurs during the encryption process, then all administrators (regardless of the Notify users option) will receive email notifications of the unsuccessful encryption process.
  3. Click the Encrypt storage button and then OK to launch the encryption process.
The time required to complete the procedure depends on the data volume. All portals will be unavailable during the encryption process. As soon as the encryption is over, the portal data will be available for work.
Encrypt storage Encrypt storage
When encryption is enabled, a newly created backup copy of the data archive will contain decrypted files. When such a copy is restored, the files will be encrypted on the disk again.
You will also need to manually start the services that make changes to the files stored on disk.
systemctl start onlyofficeMailAggregator.service
systemctl start onlyofficeMailCleaner.service
systemctl start onlyofficeMailImap.service
systemctl start onlyofficeMailWatchdog.service
systemctl start onlyofficeThumbnailBuilder.service
For Linux:
sudo service onlyofficeMailAggregator start
sudo service onlyofficeMailCleaner start
sudo service onlyofficeMailImap start
sudo service onlyofficeMailWatchdog start
sudo service onlyofficeThumbnailBuilder start
For Windows:
Go to Control Panel -> Administrative Tools -> Services and start the following services: ONLYOFFICE Mail Watchdog, ONLYOFFICE Mail Imap, ONLYOFFICE Mail Cleaner, ONLYOFFICE Mail Aggregator, ONLYOFFICE Thumbnail Builder. To do that, right click the service and choose Start.
Decrypt storage
To decrypt data on the portal,
  1. Manually stop the services that make changes to the files stored on disk as described above.
  2. Switch to the Storage section in the Control Panel.
  3. Check the Notify users that the portal will be unavailable checkbox to notify all active users via email when the decryption process starts.
    Upon the successful completion of the decryption process, all active users will also receive email notifications. If an error occurs during the decryption process, then all administrators (regardless of the Notify Users option) will receive email notifications of the unsuccessful decryption process.
  4. Click the Decrypt storage button and then OK to launch the decryption process.
    Decrypt storage Decrypt storage
You will also need to manually start the services that make changes to the files stored on disk as described above.
Docker, Windows and Linux
You Might Also Like This:
Close
